quick question on makita rotary
  • quick question on makita rotary
    is there a difference between the makita 9227 CX3 and the makita 9227c/9227cy?
    Re: quick question on Makita rotary
    Originally posted by ninee3cobra
    is there a difference between the Makita 9227 CX3 and the Makita 9227c/9227cy?
    Yes.
    The Makita 9227CX# has the letter prefix CX3 associated with the part number while the Makita 9227c uses the letter "c" with the part number and last but not least the Makita 9227cy uses the letters "c and Y" with the part number.
    Does that help?
    Seriously, here's a link to a page on the Makita website that lists all of the above polishers
    9227C
    Variable speed (0-3,000 RPM) with pre-set maximum speed dial; ideal for ultra slow polishing
    Pre-set speed setting dial (from 600-3,000 RPM) for maximum control
    Electronic speed control maintains constant speed under load
    Easily converts to a sander
    3 prong plug to prevent static electricity accumulation
    Fast and powerful polishing for clearcoat finishes
    Lock-on button for continuous use at one speed
    9227CY
    Typing in 9227 cx3 turned up nothing?
    The difference between the other two is one comes with a stick handle and the other comes with both a stick handle and a hoop handle.
    Either one is a great choice, I prefer a stick handle for what it's worth.
      Re: Re: quick question on Makita rotary
      Originally posted by Mike Phillips Typing in 9227 cx3 turned up nothing?
      Try "9227cx3" or "9227c x3" in the makita.com search field. Takes you here. The "CX3" version has both handles and adds a 21" bag (which looks nice), a wool compounding pad and wool polishing pad. It sounds like it'll be no more expensive to get the CX3 version just for the bag alone (9227CX3 Offer Expires July 31, 2006).
      Stu
