Water spots 1: Rotary 0
  • Water spots 1: Rotary 0
    Well, I think the waterspotting on the Corvette is there for good.
    I tried out a spot with a polishing pad and #83 on about 1500rpm. That didnt' do anything, so I kicked it up to #84 and about 1600 rpm. Still didn't remove them.
    So I picked a new spot and made two passes with a cutting pad and #84 at 1600-1650rpm. The spots were still clearly there. In fact, if I run my finger over them, you can slightly feel the edges of the spots.
    So that's about as aggressive as I think I want to get on 15 year old paint.
    So I did the hood with a polishing pad and #84, followed by a polishing pad and #83 followed by #80 via Cyclo. The water spots are slightly harder to see, but at the right angle they are quite clear.
    A few more things I learned, don't tape off emblems, tape around them a bit. I taped right at the edge, and now it's a little hazed around the hood emblem because it's too close to it to work, even by hand. It would have been better to tape off about 1/4" around the emblem.
    And thankfully I taped off areas that seem pretty flush but really aren't, like the headlights. I suspect they would have gotten very hazed or damaged otherwise. Basically anywhere there are adjoining panels, I taped over with the 2" wide tape.
    Lastly, wow does the Corvette retain heat. This time I definitely put heat in the paint, but never so much that it was uncomfortably hot to touch or rest my hand on. But what was interesting is how long it would stay hot. I could do an area, and evey a minute or more later it was still almost as hot as when I first felt it. Definitely something to be aware of for multiple passes.
    1990 Corvette ZR-1 Bright Red with Red interior Hear it!
    2002 Aurora 4.0 Cherry Metallic with Neutral interior Hear it!
    1997.5 Regal GS Jasper Green Pearl with Medium Gray interior
    Re: Water spots 1: Rotary 0
    I distinctly remember the shot of your hood from your post on this a few weeks ago. Those spots looked deep from the picture and I was hoping they weren't too bad to be removed.
    Good choice. I'd hate to see you do more and damage it, which is likely given the age and the extreme nature of the spotting.
    At least you made some improvements. If it's ever time for a repaint, for some reason, THEN you could get out there and do some testing.
    I have a soft spot for those first 1990 ZR-1s. I forgot what production number, but my Dad bought a new one in red with the saddle interior.
    See the big picture, enjoy the details
      Well, I think the waterspotting on the Corvette is there for good... that's about as aggressive as I think I want to get on 15 year old paint. .
      Yeah, good call Better imperfect original paint than a repaint.
      Sounds like a good learning experience too.
      Practical Perfectionist
