what pad and speed to use with rubbing compound?
  • what pad and speed to use with rubbing compound?
    Hi,
    This is my first post, but i've been browsing the forums for the longest time.
    I noticed on the sticky thread with the pad/speed/product recommendations, compounds were listed with a rotary only... thing is, with my paint, i have some imperfections/cracks on my clear (or i hope its the clear and not under it). I've tried M80 and M83 with no success, and I dont want to go rotary just yet. I have a Megs cutting pad (the brown/red color pad) thats sitting around in its unopened plastic... so i just use that with rubbing compound? if so, what speed should i use? I have a lot of other megs pads as well....
    any help would be great.
    Hi dc11r,
    Welcome to Meguiar's Online!
    Meguiar's doesn't recommend using either of their compounds or the W-7006 foam cutting pad with the dual action polisher and if M83 with a W-8006 foam polishing pad when used with the dual action polisher isn't' aggressive enough then it's time to break out the rotary buffer or take it to a Professional.
    Read through this thread...
      Trying to do "rotary work with the PC" can be a lot riskier than just using the rotary.
      Note that "rubbing compound" covers a lot of different products, gotta be careful as some will work fine by PC/hand but many will not.
      And if the clear's really *cracked* there's nothing you can do to fix it.
      Gee, that's a bummer of a reply, huh?
      Edit: maybe the newly reformulated #2 Fine Cut Cleaner would be something to consider.
      Practical Perfectionist
