Which Type of Pads?
  • Which Type of Pads?
    Which type of pads would you use for the following types of Meguiars products with a PC 7224?
    Deep Crystal Paint Cleaner -
    Deep Crystal Polish -
    NXT Generation Tech Paste Wax -
    RonW.
    Re: Which Type of Pads?
    Originally posted by RonW
    Which type of pads would you use for the following types of Meguiar's products with a PC 7224?
    RonW.
    Hi Ron,
    You can use either our W-8006 Polishing pad for all of the above products. Typically if you have pre-cleaned the paint with a paint cleaner or a cleaner polish you would then use a softer pad to apply the wax, in this example you would use our W-9006 Finishing pad to apply the NXT Tech Paste Wax.
    The idea being that you can modify the aggressiveness or non-aggressiveness of a product by changing the application material.
    If you're trying to remove swirls, or scratches, then you're going to need something more aggressive than the Deep Crystal Paint Cleaner as it is our most gentle paint cleaner using only chemical cleaners for it's cleaning ability.
    For example, you cannot remove swirls like you see below with the products you have.
