Hello everyone,
I am not sure this question has been brought up before but I am unable to find the answer I am looking for so I have to make a post to ask here.
I have watch plenty of youtube videos and posts that demonstrate the cruise control feature of the Meguiar's DA Polisher G110V2 (or G220V2 for the place I am living at).
Typical scene in the video is the user turns on the machine, it spins, then applies pressure on top, and the sound of the machine changes, which is claimed to be an indication of cruise control in action (I do not doubt that), and then pressure released, the sound of the machine changes again to the state like the beginning.
Posts explaining the cruise control feature typically just telling the readers that there is a circuit in the machine, once it senses the pad rotation is about to bog down, it feeds more torque to the motor in an attempt to keep the pad rotating. It does not explain what means the circuit uses to sense the pad is about to bog down though (I do not blame that since this is more like electrical/electronic discussion). There is also no explanation on how far the cruise control can help at each speed setting used by the user.
So I have to make assumption here.
I am assuming the cruise control will automatically increases the speed setting when it is triggered on to a higher speed setting than the one the user is currently using. For example, if I was running at speed 3 on the dial, I press on the pad till it almost bog down, then the cruise control increase it to 4, maybe even 5 or 6 if bog down still continue to be sensed by the circuit.
Thank you!
Thank you!
