Buffer/Polisher Help
  • Buffer/Polisher Help
    Hello,
    Each time I read through detailing posts, I'm confused.
    I see DA, PC, Rotary, Orbital, etc, etc...
    I don't quite understand what the difference between these are?
    The only one I know is DA, which is Dual Action, correct?
    If someone could help me out and tell me what each one is and what is good for what, that'd be great.
    Thanks!
    A confused Megs Citizen
    #21 - Synthetic Sealant For Sale!
    Will ship internationally!
    Check the 'For Sale' section.
    Also selling #7 & Backing Plates
    pc = portor cable, rotary is a high speed buffer, orbital is basiclly for waxing
    Jeff
      DA (Dual action polisher), PC (Porter Cable), and G100 (Meguiar's version of the PC) are the same machine. The buffing shaft orbits, but the pad has no torque to make it spin.....The pad spins freely if you touch it, but it wiil not spin once the buffer is in use. This type of machine is great for minor to moderated paint defects & swirls, and is very safe to use.
      The rotary buffer on the other hand is much like a grinder, or a drill, in that the buffing pad rotates under torque. It is mainly used for correcting serious paint defects. A rotary can cause serious paint damage in unskilled hands.
      The orbital machines are the ones you see in the Wal-Mart, K-Mart, type of stores. It has the same orbiting characteristics as the PC, but it is not built for heavy duty use, and is limited to light polishing and waxing......Plus the pads are not too great either.
      I recommend the G100 from Meguiars. It comes with a lifetime, "no questions asked" warranty, and is easy to use, and gives great results.
      r. b.
        Hey rusty bumber where at in nc might you be?
        Jeff
          Originally posted by alanceperson
          Hey rusty bumper where at in nc might you be?
          Just south of Dallas.
          r. b.
            rotary/orbit
            dear rb.
            thank you for your recomendation about polishing machine's
            i am using makita angle polisher with adjustable switch.
            with wool pad for diamound cut
            now my question can i use the same machine for speed glaze
            with foam pad...or i must get the orbit machine...
            on the other hand.. i've got dewalt angle orbit sander
            with adjustable speed.. can i use it as polisher
            it looks like a small dewalt griner... but its orbit
            and speed adjustment.
            thank you
            ga
            great adventure
              Re: rotary/orbit
              Originally posted by great adventure
              dear rb.
              thank you
              ga
              Hi great adventure.......Welcome to MOL.
              Speed Glaze is one of Meguiar's most versatile products, in that it can be used by hand, orbital, DA Polisher, and rotary buffer. It even has some protection qualities to it.........Not bad for a cleaner/ polish.
              If you use it with a rotary, then I would recommend Meguiar's W-8006 foam polishing pad.
              If your Dewalt sander accepts a 5/16" arbor screw, then you might be able to use Meguiar's DA velcro buffing system It comes with the backing plate plus 2 polishing pads, and 1 finishing pad.
              r. b.
                thanks for ur recomendation
                THANKS DEAR FOR YOUR HELP,
                YES, I AGREE WITH YOU THE MEGUAIRS THE THE BEST
                POLISHIN AND REALASE WAX I EVER USED... I BEEN USING
                MIRROR GLAZE SINCE I START BUILDING MY FIRST BOAT MOLD.
                MY THE WAY I DONT NEED TO FIX A 5/16 SCREW IN MY MAHCINE
                ITS DUAL ACTION... WITH STICK PAD...
                WILL TRY AND LET YOU NOW
                THANK YOU...
                great adventure
