Possible to use DA Power System Pads with DA Polisher?
  • Possible to use DA Power System Pads with DA Polisher?
    I have some pads from the DA Power System, since I recently purchased DA Polisher I wanted to know I these can be used with it.
    If yes what bp should I use with them
    Re: Possible to use DA Power System Pads with DA Polisher?
    I believe the are the same as the Soft Buff 4 inch pads? Either way use a 3 inch backing plate. both tools have the same action so to speak, the DA has more speed and power than the power system but you should be ok.
      I have a 4" lake country backing plate that works with 4" pads.
        I used my DA power system pads with a 3" BP...I believe the velcro diameter is 3" on the pads...
        "STRIFE" aka Phil
          S3BP 3" Professional Backing Plate
            This is the one I use with 4" pads. It's actually a 3.5" backing plate
            3.5" Dual Action Flexible Backing Plate - A molded urethane backing plate for excellent flexibility and balance. If German carmakers think this backing plate is good enough to use on their top-of-the-line vehicles, you can bet it is the best plate ...
            The Flexible Backing Plate LC-43-085DA measures 3.5 Inches in Diameter and is perfect for our 4" Spot Buff Pads.
              thanks for the good news, will pick up a bp for them.
