question
  • question
    i got d/a megures mashine and i wish to use m105 and d/a cut micro fiber disk ,can i use these things togheter? i ask bicouse i sow that disk goes whit d300 paste
    so can i mix or i must use yelow pad
    thanks
    Re: question
    Although D300 is intended to be used with the MF cutting pad, you could substitue M105 with the MF pad. You want to use the same technique with M105 as you would with D300. You also want to prep the pad just as you would with D300.
      Re: question
      It can be a stronger combination though, so may leave marring on some paint, that would need cleaned up after.
        Re: question
        While you certainly can use M105 (or any other compound for that matter) with the microfiber cutting disc, you should be aware that you will see more dust with M105 than you will with D300 and wipe off may not be quite as easy, either. Otherwise, everything that you would do with D300 on microfiber you should do with M105: fully prime the pad before use; use just 3 very small drops of product for each section pass; clean the pad with a pad brush or, preferably, with compressed air after every section pass. These three steps are critical to success with the DA Microfiber System, regardless of compound used.
          Ok thanks for speed answer.and 2nd question is can use mf whit other pastes such m 205,uuc...etc bicouse i dont like yelow pads they sometes left swirls,i wish to avoid yelow pads.bicouse of that i asked question and what speed to use
          I wish to uae on italian car alf a romeo they got i think soft paint...
