I am going to use the 205 polish with a random orbit buffer. What pad do you recommend for the polish?
Buffing with polish
Re: Buffing with polish
The pad you select depends on what you're trying to accomplish and how the paint responds. M205 is a finishing polish with a non diminishing abrasive. Since it's a finishing polish it doesn't offer a lot of cutting ability so if your goal is the removal of major swirls it may let you down, even with a polishing pad. If your paint is pretty soft, on the other hand, M205 may do a great job of light swirl removal with a polishing pad. Generally speaking, a finishing polish is used following a compounding step with the goal being increased gloss and clarity, and perhaps even the removal of a light compounding haze. In those situations it's very common to use a finishing pad with M205. As you can see, the short answer to this question (and so many other questions regarding paint correction) is "it depends".
What kind of car are you working on, what's the condition of the paint, and what are your goals?Michael Stoops
Originally posted by Michael Stoops View PostThe pad you select depends on what you're trying to accomplish and how the paint responds. M205 is a finishing polish with a non diminishing abrasive. Since it's a finishing polish it doesn't offer a lot of cutting ability so if your goal is the removal of major swirls it may let you down, even with a polishing pad. If your paint is pretty soft, on the other hand, M205 may do a great job of light swirl removal with a polishing pad. Generally speaking, a finishing polish is used following a compounding step with the goal being increased gloss and clarity, and perhaps even the removal of a light compounding haze. In those situations it's very common to use a finishing pad with M205. As you can see, the short answer to this question (and so many other questions regarding paint correction) is "it depends".
