So i bought the DAMF system in 6" but after reading some of the DAMF info posted on a recent thread it shows that only 5" is suggested for use on the G110v2. Is there going to be an ill affect on anything, i'd hate to use a nonrecommended size. It gets worse because I liked the system so much i just invested in a bunch of new 6" MF pads. My results are good. I still could use some better technique but that is user error not product. What should I do?
DAMF 5" or 6" when using G110v2
Re: DAMF 5" or 6" when using G110v2
This is a reply to my post on a related topic:
Originally posted by Nicholas Winn View PostIf you own a Meguiar's Dual Action Polisher whether the G100, G110, or G110v2 or any other traditional D/A you will want to use the 5 Inch Discs with the W67DA Backing Plate. More detailed information on this system can be located in the following below threads:
Introducing Meguiar's D/A Microfiber Correction System
Using Meguiar's D/A Microfiber Correction SystemI'm crafty, but not good at crafts.
The system was fine tuned to use the 5" discs on a DA at 4800 opm and 3800 opm for cutting and finishing. That is specifically speeds 4 and 3, respectively, on the G110v2. We put a lot of development into this system and these settings, so we highly recommend using it this way. While you can use the 6" discs on a DA you will see reduced cut, which sort of defeats the purpose of the system. The 6" discs were developed so that users of larger format tools, like the Flex 3401 and others with semi-fixed backing plates can still use the system.Michael Stoops
Thanks guys, looks like i will need to invest in the 5", hopefully I can return the 6" pads i have if unused. I didn't notice any notes on the online retailers sight mentioning this. A little sad, but maybe i can find someone to pick up the 6" stuff from me. If not than I will have some nice microfiber frisbees for my daughter to play with.
Why not purchase a smaller backing plate and trim the larger pads to fit ?Live like you're not afraid to die.Don't be scared, just enjoy your ride. Chris Ledoux RIP
PAUL SPARKS / Distinctive Auto Detailing
317-513-4678
