Hello.
I need some clarification on Meguiar's product pads and backing plates.
Under the consumer line:
W-DAV99 is DA Velcro Buffing System. This product has two W-8006 and one W-9006 pad. These pads are permanently attached to a backing plate. I would screw out the pad and backing plate when I wanted to switch to another chemical product. Am I correct in my understanding of the combination of backing plate with foam pad as one unit? (wish they had a picture)
WDAV99-B Set of 3 Polishing Pads. These pads are different than the ones above. I would need to get the backing plate from the professional line to use with this? They attach with velcro. 3 pads.
Under the professional line:
I can purchase individual SOFTBUFFâ„¢ Finishing Pad W-9006,
Soft Buff® Foam Polishing Pads W-8006. What is the difference between these individual pads and the WDAV99-B pads above?
I can purchase and individual backing plate-- Dual-Action Polisher Backing Plates-- W-64DA.
I am confused. The G100 kit sold comes with the professional backing plate and the professional pad?
What is the deal between the products in the two categories of professional versus consumer?
If my perception of the products is correct, DA Velcro Buffing System is cheap and I should be getting the backing plate
W-64DA from the professional line.
Assuming the above sentence was correct, I now need to get pads. I can buy the pads individually from the professional line, or I can buy a 3pack from the consumer line--WDAV99-B Set of 3 Polishing Pads-- and save a couple of bucks??
Thank you in advance for clearing up my total confusion.
