Hi everyone,
I used a DA for the first time last night -- I had someone give me a Porter Cable 7274 (the original model, NOT the XP). I found it to be a very nice tool, but slightly more labor intensive than I thought. I was working on a 2001 Oldsmobile Aurora, in a dark metallic champagne color. I washed it with Gold Class and gave it a quick clay with ClayMagic clay and lube.
I used Ultimate Compound on a W8007, and NXT 2.0 Liquid on a W9007 pad.
Some Questions and Observations I'm looking for a bit of feedback on:
1) The PC seemed to stop rotating pretty easily with the application of downward pressure onto the machine. I assume this is just a function of the motor not being as powerful as some of the other DA polishers out there. I would also assume that this machine is still capable of doing sufficient defect correction with something like Ultimate Compound, correct?
2) I had a very hard time telling how much product to use, and how often to reapply, and how often to work it in. It was very humid in the garage that I was working in, which I believe was helping the working time. For a sedan, how many times would you typically have to do the "X-pattern" application onto the pad for a hood or body panel? I only have one pad, and I also think I need to clean the pad more next time throughout the process. I made a few passes over each section until the ultimate compound appeared to be all worked in, then wiped off.
3) The waxing was a little better, as the pad didn't seem to need much wax after the first few applications of product. I probably only applied wax to the pad 5 or 6 times for the whole car, and only a small line across the pad a few centimeters long.
4) I know I need to clean the pads on the fly better, but is it okay to do an entire car on one pad? I know it's not ideal, but I'm not ready to spend $80 on pads so I can swap them out constantly.
Thanks,
Alex
Thanks,
Alex
