If my UC or UP dry out while polishing ?
  • If my UC or UP dry out while polishing ?
    Everything I've read tells me that Ultimate compound and Ultimate Polish should not be allowed to dry while applying with the DA polisher.
    I am relatively new to my Megs DA and after getting thru some initial learning curves, find that I have difficulty determining if it is too dry/wet and If I have worked too long. What would be the signs of the UC or UP was worked a little too long and was drying before I stopped ?
    Often it looks like it is dry while making passes, swipe no mark, however, when I stop there is a large mass of wet material indicating the pad is still saturated .
    Any comments or suggestions appreciated, I realize it is something I will have to judge for myself. It is just the most difficult area for me right now
    Re: If my UC or UP dry out while polishing ?
    Read this: http://www.meguiarsonline.com/forums...and-similar%29
    2019 Ford F-150 XLT SPORT 4X4 Ecoboost
      Yes,
      I have , One of many information filled threads. Just trying to get some feedback on relationship of dusting to pad saturation.
      Thank yopu
        Both of those products should have a long working time, especially the Ultimate Polish. Usually 4 -5 passes or you start to see the product is getting very thin and then wipe off to inspect your work, re-apply more product if needed. You will need to clean your pad off on the fly or use a clean pad after a section or two to prevent build-up on the pad. UP has a lot of polishing oils in it plus it has an incredibly long work time, so drying is not usually too much of a problem. But test swipes will tell you that.
