Can I use the same pad?
  • Can I use the same pad?
    Can I used the same foam pad for Ulitmate Polish that I use for compounds?
    Re: Can I use the same pad?
    Only if you clean it and if its right color?
      It's just a white foam pad that came with a Turtle Wax random orbital I bought. How do you properly clean them?
        I think that white pad is not to be used directly. If I am not mistaking its a foam pad that you put buffing bonnet over it?
          Nevermind I was thinking it was white for some reason its yellow.
            Again I think that white foam pad is ONLY backing for the white bonnet. Any instructions with your polisher?
            White pad that is fixed to your polisher will do nothing for you. Is this 8" polisher?
              No its a 6 inch. It came with 2 bonnets, a foam one and a microfiber one.
                You can use your foam bonnet for polish.
