Re: How much paint am I removing?
How are you applying this? Rotary Buffer? DA Polisher? Traditional Orbital Buffer? By Hand?
Regardless, you won't remove enough to measure if any assuming you're using a foam polishing or finishing pad. M03 is a non-abrasive polish rich in polishing oils.
It's completely non-aggressive. If you want a little cleaning power to prepare the finish for waxing then go with M09 Swirl Remover 2.0 which is a very non-aggressive cleaner/polish.
Originally posted by Ashton
View Post
View Post
