is it ok to use scratchx with the g100
  • is it ok to use scratchx with the g100
    picked up some scratch x. is this ok to use with the g100 for scratch removal,and would i get the same end effect by using scratchx,then #80,then 2x nxt or should i buy some #83, then go 83,80,then 2x nxt, basically im wondering if the small bottle of scratchx is an ok subistute for #83 for which i really dont need a huge bottle of, only have a few scratches in my wifes car than i will try to fix,hope this makes sense to all you pros..
    if u have a G100, just use #80, you will probably get better results than scratch X.
    scratch X will gum up real easily if u use the G100 with it.
      I'd hit the scratches up with the scratch x by hand first, then go over the entire vehicle with #80 via pc. Just treat the isolated areas and blend it all together with the 80.
        thanks guys,im always learning....
          I agree. The above is a great technique. Here's why, believe it or not, for deeper scratches or below surface defects, you can often times remove these defects faster and more efficiently by hand using ScratchX than by using a dual action polisher. The reason why is because by hand you can exert a lot of pressure to a small area, this allows you to focus all our efforts to the defect.
          The dual action polisher applies equal pressure to a foam pad with a 6" diameter surface which dissipates your pressure and spreads the cleaning/abrading action over a larger area.
          Because the dual action polisher is capable of producing a nicer looking finish than you can achieve by hand, using a combination of hand and machine will produce the results you want the most effectively.
          Spot clean with ScratchX, (remove below surface defects), then re-polish those areas along with the entire car for a flawless finish.
