Velcro on W8207
  • Velcro on W8207
    I've used this pad for my booth and roof, washed it, used it once more, and today I realized it's not sticking any longer to my Makita DA.
    Any thoughts as to why?
    Cheers
    Doug
    Re: Velcro on W8207
    Any thoughts about this velcro issue?
      Re: Velcro on W8207
      How do you wash it?
        Re: Velcro on W8207
        machine wash, laundry detergent, no softener, cold wash.
          Re: Velcro on W8207
          We know this is an old thread and apologize for not seeing it earlier.
          What backing plate are you using with the pad? How old it is? Your issue might be a compatibility issue between the type of hook & loop materials on the two pieces.
            Re: Velcro on W8207
            It was originally used with Makita sander/DA on a 125mm plate.
            My G220 landed with 5" plate, now I've purchased a 6" (both made by megs).
            The pad, backing plates and G220 are not more then 2 months old.
            Same situation with both backing plates, it simply doesn't hold on.
            The pad was machine washed with other pads, no problems.
            Strange, isn't it?!
              Re: Velcro on W8207
              So you're using our backing plates and you have several of our pads, all treated the same way, but only ONE is having this issue? We would suggest you contact Meguiar's Australia about a replacement then. http://www.meguiars.com.au/
