Will the product I already own be usefull with a 7424 DA?
  • Will the product I already own be usefull with a 7424 DA?
    I guess this question was already answered but I can't find the answer anywhere.
    I want to remove light swirls
    I Just bought a 7424xp DA and I'm wondering if I can use the products I already have or do I have to buy other products.
    I have:
    scratchx 2.0
    Deep Crystal Polish
    Deep Crystal Paint cleaner
    NXT wax
    I also bought Lake Country (one of each):
    Orange
    White
    Gray
    Blue
    Will I be able to do something nice or do I need something else?
    Re: Will the product I already own be usefull with a 7424 DA?
    What are you working on? Photos would help, too.
      Light swirls
      I don't have pics but I just want to remove light swirls that are evreywhere on the ar after winter.
      It's a 2009 model. Mitsubushi Lancer GTS Sportback.
        well well, does anybody know?
          Yes, you can use those products with your D/A, no problem. The ScratchX 2.0 will be the most aggressive of them and should be coupled with the white pad for starters. If you find you need something more aggressive because the swirls aren't coming out, pick up some Ultimate Compound (about $10 at you local auto parts store or even WalMart) and use it with the same white pad. The orange pad may prove to be more aggressive than you actually need. Whether ScratchX 2.0 or UC, run the tool at speed 5 and apply moderate pressure.
          When applying DC Polish or NXT you would switch to a softer pad and slow the machine down to speed 3 or so. Use less pressure when applying either of these products than you did with the paint cleaners.
            Thanks Michael. That was usefull.
