Hey, guys. I have recently purchased a black 07 GS350 that I'm working on getting cleaned up. The paint on this car is pretty bad and has some substantial swirling and oxidation.
I am using the following method:
wash/clay
M105 with an orange pad on a PC 7424XP
M205 with a white pad on a PC 7424XP
Blackfire Wet Diamond on a blue pad
Dodo Juice Purple Haze wax
I prime the pads with Quick Detailer and then spread the polish on first with the buffer turned off and then I turn it to speed 3 to spread the polish evenly. I will then turn it up to speed 5 and spend about three to five minutes on an area moving very slowly and then gradually speeding up. I apply as much pressure as I can without causing the buffer to bog down. At the end I turn it back down to speed 3 and make a few more passes. Then I will wipe off the residue with a microfiber towel.
I'm getting a noticeable improvement in the paint. The oxidation is gone, however it's not perfect. I still see some swirling in the paint and I would like to know what I can do to achieve near 100% correction. Do I need to try a different product or should I order some purple pads and try the M105 with the purple pad? I like to think I'm going slow enough and that I'm applying enough pressure, but this is only my second car to detail. My first one was my 05 TL which I got very good results with, but again, not the amount of correction that I'm seeing in the Show Your Results forum that the professionals are able to achieve.
Thanks for any help you can give me.
wash/clay
