OK to apply ColorX with the G110?
  • OK to apply ColorX with the G110?
    My process for waxing my black Ford Escape is to 1) Wash with Gold Class shampoo; 2) clay; 3) ColorX; and 4) Wax with #26. I love the results.
    At any rate, my question is whether or not it is OK to apply ColorX with the new G110v2 I got for Christmas? I have been doing it by hand, but would like to take advantage of the machine if it is safe.
    Re: OK to apply ColorX with the G110?
    Yes you can.
    You can apply both ColorX and M26 using the G110v2.
    You can use Colorx with the Polishing or Finishing Pad, depending on the condition and your goals. M26 Finishing Pad and you'll have great results
      Not only is it OK to apply ColorX via the G110v2 but it will probably give you the most out of the product. The tool will give you a more consistent, more efficient application of the product.
      If you're using the liquid version of M26 then apply it with the G110v2 as well.
        Thanks so much. This past weekend was actually at 60+ degrees in Raleigh, so I am hopeful that the winter is almost over and I can do my spring waxing soon. I am looking forward to using the polisher to apply the ColorX and the wax (I do use the liquid).
          Colorx works great with the D/A. When I first tried it, I was surprised on how much dirt/contamination it pulled out (you will see on the pad).
            ColorX + DA = absolutely !
            used it that way many times. makes my moms paint really pop. Its also nice on the DA cause colorX is a little more on the creamier side so you can actually work the product in for a little longer
            Addicted
              As others have stated. This will maximize its potential. When your done we need pics. lol.
