What pad should I use when applying M105 and M205?
What pad to use?
Re: What pad to use?
It will depend on what you are trying to accomplish ?
Lets assume you are working by machine(s).....Since M105 is used to remove defects, it should/could be used with primarilly the following...
Rotary Buffer - Our cutting and/or polishing pads
D/A Polisher - Our polishing pads
M205 is used to remove swirls and create high gloss, it should/could be used primarilly with the following...
Rotary Buffer - Our polishing and/or finishing pads
D/A Polisher - Our polishing and/or finishing pads
Keep in mind, pads are just one element that can adjust the total "cutting/swirl removal" power of what you are doing...So when you use different pads with different products, you can/will get different results. That gives you the freedom to work successfully in many different situations.
Mike Pennington
Meguiar's, Inc.
800-854-8073
mpennington@meguiars.com
