Well, after having a few test details with borrowed Flex's I stepped to the plate and made the call over to Rick at ADS. Rick has a Flex Complete Kit that comes with the 3401, the Flex bag, 6 LC CCS beveled pads in your choice of color, and 3 free microfiber towels all for $320...that's the best deal on the net by far and when you factor in Rick's longstanding reputation for customer service excellence it's a no-brainer. He was also able to procure the sought-after side handle that comes with the rotary Flex version for me...
Big brown truck brought this in today...
I decided to pull out my trusty PC-7424 for some side by side comparisons. Here's the two for size reference purposes...
And here's a shot with the side handles attached...
Some people had asked me about the manueverability of the Flex versus the PC-7424 or G110. Here's some one-handed wielding shots to give you an idea of the size and grip...
From a one-handed standpoint the Flex is longer, narrower, and slightly heavier so the natural grip is not as comfortable as the PC. In addition the forced rotation aspect doesn't lend itself to a lot of weak gripped one-handed situations so I would not recommend it.
After turning on the Flex to insure everything was working properly I can tell you the machine just feels powerful. Going beyond speed setting 3 really lets you know you're dealing with a more serious machine than the PC and the longer throw (8mm for the Flex) gives you a smoother vibration feel which translates to longer working times with less fatigue.
Features I liked very much are the smooth start variable-speed trigger meaning I don't have to stop to change speed settings to spread polish, then work product, then conduct a finishing pass. If a speed change is required the speed dial is conveniently located near your thumb. The trigger lock is also neat and readily accessible just above the trigger itself. The Flex bag holds the machine nicely and is sturdily built. Paperwork with the Flex describes a 2-year warranty.
The side handle is great for large areas and horizontal surfaces as it allows you to constantly control the machine's level even when your stretched out working on the center of a hood or roof. The bail handle is great for adding pressure and vertical panel control. I'm glad I got both. There is also a lot less transmitted vibration through the "Soft-Vib" side handle. The extra 3 feet of cord gives me more room to work than the PC and it's hard to explain but the cord for the Flex feels higher in quality and construction. In fact, the whole machine does. You really feel like your working with a professional machine...
Some of the things I did not like initially where the added weight over the PC (although not much) and the lack of interchangeable backing plates. The machine itself also sits lower to the panel you're working on so a little more attention is needed in tight spaces. Also, the instructions could be a bit more detailed but, hey, they did come in 17 languages...
All in all, I really like this machine and holding it really made me remember why I enjoyed those details with it. The corrective power over the PC is dramatic and should even higher levels of correction be needed, the KBM works here too. Over the coming weeks I have three cars (two Toyota Corolla S's and a BMW 3-series) that will be the first completed with this machine. Stay tuned for my side by side comparisons in performance and pictoral accounts. Thanks for reading...
