What do you guys do about the A pillar
  • What do you guys do about the A pillar
    What do you guys do about the A pillars and other narrow spots on a vehicle. I'm buffing out a 95 suburban if it helps to know the vehicle in question. It took me a while to figure out the DA and how to keep the holograms under control, but now I'm loving it!
    Re: What do you guys do about the A pillar
    4" Lake Country CCS pads are valuable here on the pillars. They also make a backing plate for the smaller pads on the DA. Unfortunately, Meguiar's does not make 3" or 4" pads, so we are stuck buying our products from another source You can do it with the larger 6.5 pads(I've done it many, many times), but it is difficult to get perfect results.
    2008 Meguiar's Batmobile Team
    2008 Meguiar's/Ford SEMA Team
    2009 Meguiar's/Ford SEMA Team
    2010 Meguiar's/Ford SEMA Team
      I use the 4" CCS "Spot Buff" pads to get the A-pillars, around the rear deck lids or trunks of vehicles, around emblems or weird body contours, etc.
      I also have an assortment of foam applicators from CCS for hand application in areas like under door handles, under the wing, etc. Now that I'm moving to a Flex I don't have the 4" pad option so the hand buffing and careful use of the Flex would be my only options (unless I buy another PC).
        You could always do the A pillar by hand.
          I do the "a" pillars by hand also.
          2011 Ford Mustang GT Cali Special
          2012 Kia Sorento EX
            I also use the Lake Country 4" CCS pads and backing plate on A pillars, makes easy work of the A pillars and other tight areas.
            The Best Last Step, is the step backwards you take to admire your work!
            If you use #7 on your car, you're not in good company... you're in GREAT company!
