M84,M85,M95 with DA?
  • M84,M85,M95 with DA?
    Hi, I used M83, M82 and M80 today, and I really like these products.
    M83 works very well. I personal think that it works much better than Griot's products because I have used their products for three years until today. However, there are still some deep scratches on my engin hood, and I am wondering if DA can work with M84,M85 and M95 because I am not really read to use rotary-polisher. Also, I want to know if 2009 ULTIMATE COMPOUND will work with DA too. Is it stronger than M83, M84, or M85?
    Re: M84,M85,M95 with DA?
    Ultimate compound will work for DA. I used it with my PC 7424 with good results
    2008 Toyota Corolla 5-spd
    2005 Honda CRF250R
    2002 kawasaki Ninja ZX9R
      You can definately use the Ultimate Compound with the DA. In order to get out the deep scratches, it will probably have to be done by rotary. Have you tried Nxt2.0 on the deep scratches to reduce them? That might be best to reduce the scratches without having to use a rotary.
      The Ultimate Compound is more aggressive than the M83. I believe it is less aggressive than M84 and M85, but I am not completely sure.
        M84,M85, and M95 are not recommended for DA polisher use. They will leave a micro marred finish behind requiring additional polishing. If you want something that will be DA friendly you could use the Ultimate compound or get yourself some of the reformulated 105 ultra cut compound. ADS sells it as a 12 ounce sample,32 ounce bottle, or by the gallon.
        Andrew
        2013 Race Red F-150 SCREW
