Difference in pads
  • Difference in pads
    I have a question regarding the soft buff pads for the G110. I have a local retailer where I purchased my G110 with a W8006 and W9006 pads. But included with the purchase were three pads for free. They are:
    -W8207
    -W9207
    -W7006
    What products would be used on these pads? I have yet to use them. The W7006 says it's a cutting pad, but what exactly would I put on it? Are the W8207 and W9207 any different than the W8006 and W9006 pads?
    Any info is appreciated. Thanks
    Re: Difference in pads
    Generally this is how the pads would be broken down. Although some products can be used with a couple different pads, there is a set norm.
    W8207 Polishing Pad - For removing defects using a paint cleaner or compound. A example would be M105, M80, M83, etc.
    W9207 Finishing Pad - For applying waxes and pure polishes (#7 for example).
    W7006 Cutting Pad - For severe defect remove, this pad is not meant for the DA (at least not the W7006). You will find people using this pad with a rotary and a compound most often.
    Hope that clears it up!
    Ryan
      I think if you click on each pad below and then read the initial post for each thread and then all the follow-up questions and answers, everything you ever wanted to know about these pads will be revealed.
      Washable 7" Soft Buff 2.0 Foam Pads
        Thats all the info I needed.
