For some reason I thought I read on this forum a while back that you shouldn't use the cutting pad with the DA. Am I correct about that or no? I see a lot of people talking about using their cutting pads with m105 and m83 to remove deeper scratches and defects. So what's the deal should I or should I not use the cutting pad with these products when using the DA polisher?
Should I use the Maroon Cutting Pad with M105 or M83?
Re: Should I use the Maroon Cutting Pad with M105 or M83?
The cuttingpad is not designed to use in combination with a DA.
You will need a rotarybuffer to use a cuttingpad because a DA isnt powerful enough,used on a DA it will leave marring on the paint!
Actually, the new W7207 Cutting pad is approved for use with the DA. The W7207 pad uses a different foam that's smoother than the W7006 pad.
That being said, M105 is still not approved for the DA, but M83 is just fine.Chris
Dasher Detailing Services
Originally posted by PorscheGuy997 View PostActually, the new W7207 Cutting pad is approved for use with the DA. The W7207 pad uses a different foam that's smoother than the W7006 pad.
That being said, M105 is still not approved for the DA, but M83 is just fine.I have seen the results of the W7207 and #83. It looked great and with just a pass or two of #80 with a W8207 it was ready to go.
Navy Blue Metallic Pearl 2002 Camaro Z28: Build in progress. (416" LS3/9" Rear End/TH400/200 Shot)
Superior Blue Metallic 2005 Trailblazer LS: !Badges/!Molding/20% Tint/Stealth Audio in Progress
