My main question is this: Do I need to continue more passes with the products I am using or do I need to switch to a more agressive setup with a rotary or perhaps a different product like 151? Now that you know the question, here is the lead up:
I recently bought a G110, pads, product, and instructional DVD from ADS. I watched the DVD several times, made notes, organized my materials and got ready to do a test spot.
My car is an 07 Hyndai with dark blue paint. The finish isn't in real bad shape but it could be better. It has the typical cobwebbing and some deeper scratches as illustrated by this before photo:
I got re/dy to do the test spot. Here was my process:
-Wash with GC
-Clay
-M83 w/8006 pad (3 passes)
-M80 w/8006
-NXT 2.0
I was very careful to use proper DA speed, arm speed, and pressure (yes, I had a scale nearby) as I did this so I feel confident my application is pretty close to nominal. I also want to say that I didn't start out intending to do 3 passes of M83 but one pass didn't take care of everything. Each pass yielded a better result but I stopped at 3 passes thinking that a different product or setup may give me the result I want with less time/product spent. The "after" photo below shows the improvement but it isn't perfect. Some larger scratches remain. This leads me to the question at the top of this post. How can I get the finish to where I want it to be? Is the answer more passes, more/different product, or a different/stronger tool for application?
Thanks!
-Wash with GC
-Clay
-M80 w/8006
-NXT 2.0
