ColorX via PC
  • ColorX via PC
    What pads/speed should i use on paint that needs to be brought back to life using my PC?
    using LC pads btw
    AJ Auto Detail, LLC
    Re: ColorX via PC
    Try here! Matching product to speed.
      Re: ColorX via PC
      Not too many of us use LC pads here but.....
      For the LC pads, in order of least aggressive to aggressive.
      Red Finishing
      Blue Finishing
      Black Finessing
      White Polishing
      Green Heavy Polishing
      Orange Cutting
      Yellow Cutting
      You should really try the Meguiars Pads with their products, 3 of them to do the trick, cutter, polisher and finishing pads, easy to remember (of course the wool pads too)
      The LC pads were designed for Prima Products that I have not used before, thought about it as I ran across some threads on other forums, but stuck with Meguiars products.
      My guess would be the white pad, but try in an inconspicous area first, as always.
      Aaron
        Re: ColorX via PC
        Red Finishing
        Blue Finishing
        Black Finessing
        White Polishing
        Orange Cutting
        Yellow Cutting
        Aaron
        i know what the pads aggressiveness' are... i didnt ask that
        will colorX stain trim or no?
        AJ Auto Detail, LLC
          Re: ColorX via PC
          Aaron
          On another forum, they suggested a white pad for polishing (as M66 is a "polishing" wax) or the black one, do a test spot........
          I didn't decipher if you knew what each pad did (or my brain didn't simply catch it, Night shift ***** at the ol' lock up). Most only use 4 of the pads they have.
          Black Finessing
          White Polishing
          Orange Cutting
          Yellow Cutting
          M66 as most waxes will leave white on your trim. Use painters tape to cover it first. It's a pain to get off and usually a couple of applications of some kind of trim detailer (I use Gold Class Trim Detailer, with some M40 thrown in there)
          Aaron
            Re: ColorX via PC
            .....(as M66 is a "polishing" wax)....M66 as most waxes....
            I meant ColorX
            Sorry bout that, old age is creeping on me......
            L8R
            Aaron
