DA vs Rotary
  • DA vs Rotary
    Guys,
    Met a guy recently who is a pro detailer and showed me what a rotary can do. He said that basically they can both do the same thing just the DA will take longer but is safer.
    He also said that to get the same cutting ability on a DA as Rotary you tend need to use a more agrasive combo on the DA. For example to achieve the same cutting as using #83 with a cutting pad on a rotary, you will need to use #85 with a cutting pad on a DA.
    Whats peoples thoughs on this ?
    Re: DA vs Rotary
    PC and #83 Not Cutting it
      Re: DA vs Rotary
      Originally posted by dotnetdave View Post
      Guys,
      He also said that to get the same cutting ability on a DA as Rotary you tend need to use a more aggressive combo on the DA. For example to achieve the same cutting as using #83 with a cutting pad on a rotary, you will need to use #85 with a cutting pad on a DA.
      Don't really have any thoughs on this but here are some thoughts on this...
      He needs to spend some time on this forum to get his information more accurate. We don't recommend using either M84 or M85 with a DA polisher, the are only for rotary buffers.
      Everyone and their brother is always wanting to get more aggressive with the DA polisher and the effect this has is to scour the paint and leave it dull and hazy, we call this working backwards.
      Check out the links Matt posted.
        Re: DA vs Rotary
        points noted mike, although he did do my wing with #85 and a cutting pad and followed this up with either #83 or #80 on a polishing pad.
        Mike, do you ever get to come over to the megs UK office, would be great if you did and could some of yoru famous workshops
