Help on Pads
Re: Help on Pads
Most pad manufacturers now offer some pad with a special design. The idea is to reduce the heat associated with rotary polishing. Also, they are supposed to reduce skipping and hop.
If you are using a PC, then there is no reason to use a special pad with the design.
The counter weight doesn't matter when polishing.Chris
Dasher Detailing Services
Re: Help on Pads
Just a quick tip here: if you're going to use Meguiar's polishes and/or paint cleaners then your best bet for pads is to stick with the Meguiar's brand. Their chemicals and pads are actually designed to work together. Now, that doesn't mean you can't use LC pads with Meguiar's chemicals or someone else's chemicals with Meguiar's pads, but for optimum results you'd be better off.Michael Stoops
