G100 Questions.
  • G100 Questions.
    1. Do, I need any kind of a brush to clean off the pads? I've seen guys at detail shops run something like a tooth brush over the pads on rotary buffers to clean them. Is this needed on the DA?
    2. What speed should I use to apply waxes/polishes. Also, do I want to work the wax/polish until it disappears?
    3. Is there an advantage with removing the wax/polish using the DA over a microfiber towel?
    4. Is the DA safe to use on a 3m clear bra?
    Re: G100 Questions.
    1. You want a terry cloth towel for the DA. Or a few...
    2. You work the cleaner/polish in until it is greasy clear. Then remove. Waxes you just work in over the area for a few seconds in each direction, then move on.
    3. You remove cleaners/polishes with towels. Waxes will look better removed by machine, a MF bonnet over a 7006 pad.
    4. I wouldnt.
