Questions about the DA
  • Questions about the DA
    Hey guys, I have a couple quick questions about my Dual Action Polisher. I have had for about a month now and probably detailed about 15 or so cars with it so far. To start with, wanna say that I love it. So recently the last couple of cars that I have done, it seems to be warming up a lot, I never noticed it do this before. Is this normal, doesn't seem like it should be.
    Next it seems as if it's squeaking when I shut it off (like as it's slowing down) I figured putting some WD-40 where the backing plate screws into the actual machine should fix this. Does this sound ok.
    Finally the only other thing that I figure could be causing this is the counter weight. It says only to use with 5" pads. I used Meguiars 6.5" pads. I never noticed this before, should I remove this counterweight? and if so, how would I go about doing this.
    Thanks guys.
    Dynamic Detailing
    541.668.0480
    Re: Questions about the DA
    Anyone got any possibilities for me???
    Dynamic Detailing
    541.668.0480
      Originally posted by jarred767 View Post
      …So recently the last couple of cars that I have done, it seems to be warming up a lot, I never noticed it do this before. Is this normal, doesn't seem like it should be…
      I guess it depends on how warm you're talking about. Any power tool gets warmer when you're working it hard. I've never noticed a PC getting warm enough to bother me.
      …Next it seems as if it's squeaking when I shut it off (like as it's slowing down) …
      That doesn't sound right.
      …I figured putting some WD-40 where the backing plate screws into the actual machine should fix this. Does this sound ok. …
      I doubt it would do anything good. The plate should stay threaded in tight. If yours isn't it might be a sign of some other issue.
      …Finally the only other thing that I figure could be causing this is the counter weight. It says only to use with 5" pads. I used Meguiars 6.5" pads. I never noticed this before, should I remove this counterweight? …
      The 5"/6" counterweight thing is for sanding. It doesn't matter which you use with buffing pads but you do have to use one.
      PC.
        Next it seems as if it's squeaking when I shut it off (like as it's slowing down) I figured putting some WD-40 where the backing plate screws into the actual machine should fix this. Does this sound ok. .
        Sounds like something's wearing out, not good. Is it still under warranty?
          yeah, I just got it like a month ago. Would something really wear out that fast. ???
          Doesn't seem right that it would.
          It's not hot, just kinda warmed up a bit and it never really did that before. Probably just normal for a power tool i guess.
          So about the fact that its squeaking as it slows down and the fact that that might signal something wearing out, is there anything I can do or should check?
          Dynamic Detailing
          541.668.0480
