HOW TO: Spindle/Bearing Assy Repair
  • HOW TO: Spindle/Bearing Assy Repair
    The backing pad on my PC recently developed a disturbing 'wobble.' I figured the bearings had worn out.
    I looked up on the Porter Cable site and found the parts list as well as a generic instruction on how to disassemble the PC. I really didn’t want to have to send my PC out for repair and have to wait even though detailing season is almost over and I surely didn’t want to pay labor charges if it was as easy as it seemed. Of course the first step is to remove the backing plate using the flat wrench that should have come with your PC.
    In the 2 below pictures, you can see the two torq-bit screws holding the counter weight. Sorry, but I’m not sure of the size. You can see me removing them with a bit from a cordless screwdriver. I prefer to tighten and remove the screws by hand since the PC is made of soft aluminum and it would be very easy to strip out the threads.
    In the picture below, you can see the spindle is fully exposed with the removal of the weight. Now you need to reinstall the backing plate.
    Below you can see the flat wrench is inserted between the backing plate and the buffer casing. The red arrow shows the flat wrench and the yellow is the spindle. For illustration purposes the green arrow shows how you will use the flat wrench as a lever, although in this picture the weight is still on. Not much pressure is need and the bearing assembly will slide out.
    This next picture shows the socket where the bearings and spindle are housed. The screw that is visible is where you would continue disassembly. When I pulled the old bearings out, the sides had a bit of grease on them, so when I replaced the bearings, I smeared some brake caliper grease on the sides of the socket.
    In this pic, I’m starting the new bearing assy into place. With the fresh grease on the walls of the socket, the new spindle & bearings popped right in almost effortlessly.
    In this final pic, everything is reassembled and you can see (indicated by the arrows) that the bearing/spindle is held in place by the counter weight.
    I found the bearing/spindle assembly by looking up the authorized repair sites and called a few until I found one that had the assembly in stock. It comes as a unit and cost just under $40.
    Don
    12/27/2015
    "Darth Camaro"
    2013 Camaro ... triple black
    323 hp V6, 6 speed manual
    Re: HOW TO: Spindle/Bearing Assy Repair
    great write up! We get pics and DC doesn't
    Patrick Yu
    2003 Honda Accord
    2008 Honda Accord EX-L V6
      I reposted over on DC, w/pics, but MOL got them first.
      Don
      12/27/2015
      "Darth Camaro"
        Nice write up! Seems simple enough, how long did this take you?
        Brandon
        2007 Black Chevy Avalanche
        My Albums: Avalanche
          If you subtract the extra time for taking pics, probably about 15 minutes max.
          Don
          12/27/2015
          "Darth Camaro"
            The bearing/spindle assembly you bought, was it possible to use the old spindle, and then just buy new bearings? I just know its easy for me to get bearings with the right dimention over her in Europe, but that whole assembly would be harder.
            Tr0nder power!
              I don't see why not. But the unit is held together by a flare at the end of the spindle which seems kind of flimsy. If you were to take a screw with machine threads and a flat head (kind of like a wood screw with machine threads), you might be able to insert that from the other side to secure the parts together.
              Don
              12/27/2015
              "Darth Camaro"
                anyone got any tips about doing the same to the G110/220 version 1? i just changed the brushes today and noticed the spidnle is getting "woobly" so i took the shrews out and it looks like it the spidnle itself, the bearing look ok at first glance..the bearing it self is easy enough to find i think, but im worried about the spindle
                  More then likely it's just the bearing and not spindle. Make sure you use HIGH Speed or high temperature grease. Do NOT overgrease because that will add additional resistance and get to hot.
                    im gonna take it with me to work so i can remove the locking ring and check better hoping its only a used bearing
                      e we go...all new bearings and brushes...almost like new
