can i use meguiars pads with Makita BO5021 ?
  • can i use meguiars pads with Makita BO5021 ?
    hi
    i read this articles "How to use the G-100 to remove swirls"
    so id like to buy Makita BO5021 to use #80 and nxt wax
    which foams do i need ? and how can i install the pads ?
    If the diameter of the backing plate is not
    bigger than 125 mm. you can use the Meg's
    pads perfectly, they have velcro at the back
    and you can put it onto your
    backing plate just like that, you can use the
    W9006 for applying your #80, and you can
    use the same type ( new clean one ) for your
    Nxt Tech Wax also
    I just love detailing
      thank you
      how can i now its not more than 125 ?
      product details
      Pad Size 4-13/16"
      Abrasive Disc Size 5"
      No Load OPM 4,000 - 12,000
      Orbit Diameter 1/8"
      AMPS 2.0
      Size(L x W x H) 11-11/32" x 4-13/16" x 5-11/16"
      Net Weight (lbs.) 3.1
      Shipping Weight (lbs.) 6.4
      makita.com/menu.php?pg=product_det&tag=BO5021K
      [Sorry, No commercial links]
      also which pad is good for #83 and for nxt wax ?
        also what dose it mean backing plate ?do i need to buy it ?
          Most of these sanders like the one in your picture don't have the power to do what you want. They operate in the same manner as the G100/PC, but they just don't have the power to move the foam pad under pressure to remove small particles of paint which is how you remove defects.
