some G100 advice needed, please help
  • some G100 advice needed, please help
    Hi everyone....I would like to start by saying whats up to all of you fellow detail enthusiasts.
    My vehicle is a silver F150, and i am not sure what i am doing wrong.....i cant get light swirls out and i am using a PC 7424 (G100) with No.#9 swirl remover and a Lake Country White polishing pad.(light-medium cut)
    My paint is in pretty decent shape, aside from some pretty light swirls and spiderwebbing which i really would like to eliminate. I thought i could be able to do it, but I see no improvments at all whatsoever. I think my problem is i am not breaking the polish down enough and i may have to do several passes. My motions with the polisher are up and down and side to side.
    I am curious what the proper technique/ polish+pad combo would be to remove these light swirls and spider webs. How long to break the polish down, how much pressure, and what speed setting? I see so many finishes go from slightly/severly swirled to like brand new. I think i need advice from those who know how to do it.
    I feel your frustration: been there, done that - still had swirls!! Grrrrr.
    I'm lucky though because I learned from no less an authority than Mike Phillips himself (well, I'm still learning of course!!). I should say that I've never used #9 but the process should be much the same regardless. You need to get all the variables down in order for this to work:
    1. set your PC at speed 5 for polishing
    2. don't use too much product, just a ring around the outer perimeter of the pad is fine
    3. work an area no larger than 2' x 2'
    4. work that area for several minutes in the up/down and back/forth motion you've described, until the polish breaks down and is almost clear on the finish - don't let it dry!
    5. use approximately 15-20lbs of downward pressure on the machine. this can be tricky to judge but the pad should deform pretty well under the machine, and a large panel (like the hood of the truck) should just about start to give under the weight also
    6. keep your hand speed nice and slow - let the machine do the work. it should take you 5-6 seconds to move 1 linear foot (give or take)
    7. overlap your passes by 50% of the diameter of the pad
    You've got a lot of surface to attack on that F-150 so dedicate some time to this, but if I can do it, anyone can!
      thanks for the info.....should help alot.
      I have heard that using a light over the panels being polished should help show how broken down a product is.
        Good lighting is essential, that's true. I work in my garage with the door fully open and a dual halogen light directly illuminating the area I'm working. I'll still pull the car out into the sunshine to double check those really tough areas.
          It might be worth throwing in the idea that #9 is very mild. If you start getting some success, but cant seem to budge a lot of the swirls, you may need to go on to something like #80.
            thanks fellas.....i think ill take the advice and some #80 and see what happens.
              I thought #9 was fairly mild but didn't want to specifically say so since I wasn't 100% sure, so thanks for that clarification Murr1525.
              2002FX4 F150, I think you'll really like #80 as you can work it for a really long time and it still wipes off very easily. Great stuff!
                Just to add on about the strengths:
                #9/#82 - Very mild
                #80 - Mild
                #83 - Medium
