Removing #16 with the G100
  • Removing #16 with the G100
    Is M-16 too "hard" of a wax to remove with the G100? I seem to have induced some type of buffer trails while trying to remove it with the PC and a MF bonnet. I had it on 5 OPM's.<--or was it the speed?
    I just want to know if it's the wax, or not so I can re-trace my steps and rule out the variables.
    I know it was the last step, because before waxing I inspected everything under the sun and it look fine.
    I'm learning to be thorough, and always make sure that the stuff that's in contact with the paint is clean.
    Alex
    Mandarina Racing
    My own personal experience has shown me that M16 after it has dried, it sets-up too hard to remove using the G100 with the bonnet.
    You're only chance would be to apply a very thin coat by machine.
    Did you check to see if the buffer trails are actually wax that just needs to be wiped off?
      I did try to swipe it, but how hard does M-16 become once it's dry and set-up?
      BTW, this only happened on a small section, so maybe you're right.
      If it is dried wax, how can I remove it now? Re-apply in that section?
      Alex
      Mandarina Racing
        Just wipe the effected area softly with a microfiber until you either remove any traces of wax or you confirm it's not wax.
        How hard does this wax get? Pretty hard. Whatever you do, don't put on a thick coat, you will learn how hard M16 gets after it sets-up.
        I've wiped M16 off cars before and left a think line of M16 on the finish that I could have swore was a scratch because it was so long and thin... but a gentle wipe and it's gone....
          Just for fun, I put a very thick coat of #16 on a test panel, left it in the sun to bake for a few hours... Thought I was going to need a hammer and chissel to shift it!
          I generally always remove waxes by hand using microfibre towels, and use the G100 (at no more than speed 3) to apply as it gets a really nice thin layer that way... I've found difficulty getting #16 off if its too thick (though most products are like that at the end of the day), but a nice thin layer will come off nice and easily, impressively so for an "old-school" paste wax.
          For difficult areas of residue that aren't removing with a gentle swipe, I find a light spray of Megs Last Touch spray detailer on the mf towel certainly helps.
          "A thing of beauty is a joy for ever: Its loveliness increases; it will never pass into nothingness; .... "
