DA Polisher Product questions.
  • #16
    Well I did it. I ordered a butt load of detailing parts. $355 to be exact.
    Things which should be on their way come Friday or so:
    1 Meguiars DA
    1 Backing Plate
    3 W8006 pads
    3 W7006 pads
    2 W9006 pads
    2 X4003 MF Booonets
    1 Small meguiars clay bar
    1 #80 Speed glaze
    1 NXT wax
    1 NXT Speed Detailer
    3 16x16 MF towels
    nxt metal polish
    #83 dual action cleaner polish - 1 gallon
    #21 sythentic sealant - just a sample for right now
    1 gallon of hyper dressing
    comeeeeee on UPS!!!!!!!
    • #17
      Well, you can tell by the views that people are reading it. I think folks dont like to jump into the middle of a thread if they dont disagree.
      Technicaly yes, you can just use #83, and it will put plenty of polishing oils onto/into the paint. Depending on your car, color, paint softness, obsessivness, etc, you can then fine tune your results with #80.
      The Pro-line is made for professionals, the cleaner/polishes combine some of the steps, to make it more efficient for professionals working with a PC. There really is no cleaner/polish in the consumer line to compare them to.
      The '80-series' has polishes, and cleaner polishes mainly for with the PC.
      The #1,#2, etc series is cleaner only, but made mainly for rotary use, where one would then follow with a PC and cleaner/polishes to get the finished look.
      Plenty of the consumer line products can be used with a PC, esp. if you have left-overs. Just have to be carefull, since they are meant for hand use, they may dry a little faster from the friction of the machine. But plenty of people use the consumer products with the PC as well.
      Just be sure to read all the How-to's and FAQ's on the PC. You really cant screw up, unless you drop it, but you'll probably need a couple passes to get the hang of it as well.
      • #18
        Originally posted by Hannibal
        as far as ADS and backordered G100s go, they are back in stock. The ala carte #1 for $149.99 nets you a DA, a pad kit, velcro backing plate, a duffle bag and a LIFETIME warranty.
        Where are these? Everything I see is $225 for the G-100.
        • #19
          Well, we cant give the link, but it is autodetailingsolutions. com . Rick has a good reputation around here, so you shouldnt have any problems.
          Check in the DA promotions.
          • #20
            Originally posted by d319
            Hannibal
            I received my #1 with some other stuff, I did not get the duffle bag. I thought you need to order $75 more on top of #1 to get the bag. Am I right?
            Sorry I have been away for a while. You get the duffle bag with the #1 package. I would email Rick and he should clear it up for you quick.
            Have any luck with the DA yet?
            http://img73.imageshack.us/img73/546...mallgz2.th.jpg
