What to use??
  • What to use??
    Hi everyone,
    I have a infiniti G35. There are some small traces of glue and fingerprints on the metal trimming and on the plastic cd player front. A friend of mine told me to use products without Ammonia on plastic because ammonia can leave residue on the surface. Can anyone suggest what product to buy and use to clean and protect the plastic surface such as the the one covering the guages, cd player surface, and metal trimming.
    Sorry, I don't know much about car detailing and cars. So, I might not use the correct terminology.
    Thank for your help!!
    This is from another thread, but it should help you to learn about Meguiar's plastic products, sounds like M17 would be a good choice.
    I have never used "PlastX", but I was wondering if it should be used for maintaining and protecting new vehicle plastic OR should it be used strictly for restoring older plastic? I thought that since "PlastX" removes scratches, it might be too strong or abrasive, for newer plastic. Any ideas? Thanks
    Any ideas?
    Thanks in advance
    PlastX can be used for maintaining plastic in new condition, but it's probably overkill because there are other plastic products more specifically formulated for your application.
    Below are all 4 of Meguiar's Plastic products, M10 Plastic polish is a non-abrasive, non-cleaning polish formulated specifically for maintaining clear plastic surfaces. This would probably be a good choice to start with.
    Mirror Glaze Clear Plastic Polish
    The finishing touch for maximum clarity and brilliance. Meguiar’s Plastic Polish provides the second step in our two-step restoration process for clear plastics. One easy application protects surfaces previously cleaned with our M-1708 Plastic Cleaner. You will reveal the materials natural brilliance, while leaving behind an anti-static coating that helps repel damaging dust and dirt.
    M-1008 ....................8 oz. (237 ml) $9.98
    Mirror Glaze Clear Plastic Cleaner
    Safely removes hairline scratches, dirt and grime. Clear plastic that has lost its clarity due to significant contamination and fine scratches should be treated using our two-step process. Meguiar’s non-abrasive, alcohol-free Plastic Cleaner aggressively cleans and removes scratches without harming the surface. Follow up with our M-1008 Plastic Polish for a perfect finish.
    M-1708 ....................8 oz. (237 ml) $9.98
    Mirror Glaze Clear Plastic Detailer
    A single-step solution that keeps clear plastic surfaces pristine. Regain the original crystalline clarity of plastic in need of restoration, using this convenient all-in-one product specially formulated by Meguiar’s. Simply spray it on and wipe it dry. You will safely remove surface contamination and achieve dramatic results on everything from window panels and instrument lenses to eyeglasses, CDs and picture frames.
    M-1808 ....................8 oz. (237 ml) $8.98
    PlastX
    This easy to use, rich gel formula quickly restores optical clarity to both rigid and flexible plastics. Cutting-edge advancements in Meguiar's exclusive Microscopic Diminishing Abrasive Technology, (MDAT), removes light oxidation, chemical degradation, surface contamination, stains and light surface scratches with ease. In addition, because our microscopic diminishing abrasives breakdown as you use them, PlastX Clear Plastic Cleaner & Polish is safe on plastic rear windows on convertible tops, aircraft windows, motorcycle fairings, face shields, headlights and taillights, instrument panels, all clear plastic boat surfaces and aquariums. Meguiar's PlastX also contains highly water-resistant polymers. These specialized hi-tech polymers provide long lasting durable protection to keep your clear plastics clear and beautiful longer. PlastX is non-toxic and does not contain any harsh solvents.
    G-12310 ....................10 oz. (296 ml) $4.99
