carpet/upholstery cleaner
  • carpet/upholstery cleaner
    I was wondering which is a good quality carpet/upholstery cleaner. I need something I can spray on and work in with a towel or something and pick up with a shop vac. I've been looking at the aerosol can in the detailer line, anyone use this one and how well does it work?
    Re: carpet/upholstery cleaner
    The Detailer Line stuff works great and you don't really need a shop vac to get it up. Work it in with a towel or a brush and get it up with another towel continually turning it until the spot is dry to the touch. Used it many times with great results.
    Andy M. Moderator
      I have always used APC+ with great results
      Thoryamaha919 AKA Evan
        Andy and Evan, thanks for the quick responses! Is the APC treatment something that you would work in with a brush and then hit it with a shop vac? What is the difference going to be between APC vs APC+?
          APC + has a citrus scent. Yes you could use it to work in with a brush and vaccuum up. It also works well. I use a lot of APC and APC +. I even use it around the house for general cleaning.
          Andy M. Moderator
            Are both methods good for seats as well as carpet?
              To be totally honest I haven't used APC to clean seats or carpet. I have however used the D line cleaner quite often. The worst stain I ever got out with it was a whole cup of spilled coffee that had been dried in the baking interior during the summer. Owner didn't even blot it up when it was first spilled. I got the whole stain out. Looked brand new.
              Mike uses APC in this thread here......
              What to use on carpets and fabric seats?
              Andy M. Moderator
                APC/APC+ are good for everything... if you dont have a jug, you should get one.
                The APC will foam a little more, can be handy if you need it to cling to something.. APC+ has a little degreaser in it.
                I couldnt even list the things I have used it for on the car and around the house/yard.
                  I have used APC+ on both carpets and seats. As stated it does foam up but i use a stiff brush to work and agitate the area then vacuum the area. Sometimes if I need I will get a damp cloth and work the area. On seats it's a little more tricky cause of the foam but I just apply APC+ to a cloth then start working the area.
