Wood steering wheel damage
  • Wood steering wheel damage
    I have a car with a replacement wood steering wheel installed. The steering wheel has scratches that looks like it was rubbed on a cement floor. I can feel the scratches. Can this be fixed? If so, what do I get? Thanks
    Re: Wood steering wheel damage
    To remove a scratch on ANY surface you have two options: fill the void/scratch/indentation with materials (paint, wood putty, cement, etc), OR lower the surrounding area to match the level of the deepest point of the scratch (sanding/polishing/compounding).
    With a wood steering wheel you will likely need to sand it, but you might want to consider filling it with wood putty and then staining the whole thing to hide it.
      Including a picture to better explain my issue
        Can you get one a little more in focus? It seems like you are showing that there is just a small area that is scratched but it follows in a line/curve according to the curvature of the wheel?
        Remove swirls my friends.
