When cleaning car interiors, and you know you will need to have the doors open for a couple of hours, what do you do to avoid draining the battery? I usually don't have this issue with any of our cars, since I always keep up on the interiors, so when I have to do anything more extensive (carpet cleaning, cleaning and dressing the plastics, etc.) it really doesn't require much time. However, I have had this come up on other details. Do you disconnect the battery? Turn off the interior lights (although I don't think you can usually disconnect door lights, lights located under the dash, etc.)? Just curious, because I want to avoid draining any batteries. Thanks!
avoiding draining the battery when doing interiors
Re: avoiding draining the battery when doing interiors
I have 20+ years in the biz and drained a battery on one vehicle ever. Turns out that vehicle had an old battery.
Afully charged GOOD battery shoul dbe able to support interior lights for a few days.
Disconnecting the batt. or turning of dome lights will help if you have an issue.
Originally posted by Superior Shine View PostI have 20+ years in the biz and drained a battery on one vehicle ever. Turns out that vehicle had an old battery.
Disconnecting the batt. or turning of dome lights will help if you have an issue.VTEC: all the lag, none of the turbo
Not to mention clear the presets on the radio (bass, treble, preset stations, etc) You'll make a customer really upset when they get back into their car and have to reset all the radio functions. Some of the fancier radios make it difficult to go through all the settings to write them down before disconnecting the battery.
ColinA common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
Turn the stereo off(of course), shut the doors when you can, if it has a dome override, then use it. Run the engine for a bit,
Anybody with an old crummy battery probably won't mind if you rush things.Daily - 09 Chevrolet Colorado - Techno gray metallic
baby - 92 Chevrolet Caprice Classic - aged, yellowed, white.
I would just use a small trickle charger and try not to disconnect the battery as it reset's everything. It can also cause starting and idling problems for the first few key cycles until the computer relearns like Gofastman said.
I killed my sis-in-law's battery in her older Ford Expedition after about an hour. I guess it was weak to start with. I put it on a charger for a few hours to bring it back to life. A couple of the fords, and mercury's I have done (for family) have an automatic timer that will shut off the interior lights after having been on for 15 min. However, if you close all the doors and open them again the 15min. starts all over again, so I try to leave the drivers door cracked until i am finished working on the interior. Turning the key or opening the trunk may also restart the cycle again? Some vehicles will turn off the dome lights by turning the dimmer switch on the dash all the way to the lowest setting. So, my approach would be to 1) try to use a switch to turn them off, 2, just time them to see it they go off while i am working, and if not, 3) maybe let the engine run a few minutes in intervals/ or have a charger handy just in case.
Happened once with one of my older cars. 1 interior light on for a couple of hours and the battery gone. That was because the battery was duff.
I've never had that problem again. If the battery is in good condition,then a couple of hours of 5w shouldn't be a problem. Just switch off what can be switched off. If the door lights are a concern,you should have an under-dash fuse for 'interior lights'.
A fully charged GOOD battery should be able to support interior lights for a few days.
With my jeep I can turn the interior lights off via the Multifunction switch where you him the dash lights. I typically keep them off unless Im trying to find something at night since there is no need to have the interior lights come on during the day when Im getting in and out.
If Im detailing I usually put a charger on the battery so I can leave the stereo on. With my sub it'll kill the battery in a matter of hours. Just be very careful if you close the hood with the charger hooked up to the battery since it may short out on the hood. Just leave the hood latched down also, down slam it shut as it may hurt the cables on the charger.
You may not have access to a charger and power though. Just make it quick and maybe start the engine every hour or so and let it run for 5-10 min.Current Jeep: 2004 Jeep Liberty with stuff
Originally posted by Mike PhillipsLive on the edge... try something new, try NXT Tech Wax 2
Originally posted by SAH Dad View PostI would just use a small trickle charger and try not to disconnect the battery as it reset's everything. It can also cause starting and idling problems for the first few key cycles until the computer relearns like Gofastman said.
That is what I do if I know I'm going to have the doors open for a long time and the car is older. Most newer cars will shut the lights off after a certain amount of time or some even have switches.
x2 for the trickle charger.
Drained batteries happen, especially on newer cars like the tahoe I just did. Interior lights, automatic seats that are moved many times, electronic rear gates, electronic retractable steps when the door opens, engine bay lights, windows up down while cleaning, etc. They all take a toll on the battery, and if a long time is spent on the interior it drainage just happens.
