Not really what I meant but still looks good and a good idea. I was talking about lines in the floor between the seats where the floor matts would be located (not under the seats).
Bissell 1425-1 Little Green ProHeat Wet/Dry Vacuum
yeah what i was trying to say is that the lines last about as long in the car as they do with vacuum lines in the house, once you walk through they are pretty much gone here is a pic of what i think you are looking for, the more plush a carpet is the better lines you are going to have, this truck has very thin low nap carpet
"at the end of the game, the king and the pawn go in the same box"
I'm picking up what your putting down. Your pic answered my question. I understand how long the lines will last. I was wondering how you work around the obstacles. the pics says it all. I haven't tried the lines going side to side. I've tried to leave lines front to back. Doesn't work that well.
Back to topic... I used my heated extractor today with great results. I think I'm getting the hang of it. Except for the line thing!! The carpet dried real quick too.
carspainc.com---> This "wickering" thing you mentioned, I did notice the first time I used the LGM (a while back) a nice big spot showed up after drying. I went over the area again. Today I didn't see any problems after using my extractor.
Originally posted by scrub
cheater!!
I'll have to try that thanks for the tip my friend.
but you are right it is very frustrating when you can't get the lines real nice , because there is an obsticle or the vacuum nossle does not touch the carpet all the way...
I will assume what you're talking about is as simple as getting a scrub (no pun) brush and make the designs. Or am I missing other critical elements on how to get the results like yours?? A specific kind of brush??
when i do my lil fancy lines , let's say on the driver site carpet (cuz that is the one with the most problems) then i start with up and down pattern behind the pedals to the floor piece... as soon as i get enough room for the nossle , then i change to left and right pattern (it's easier to me , as i dont have to struggle with the seat) then i get my iron brush (got that name for its looks, it's plastic , though
) and go over the pattern once more . it gives it a more even look.
Ok I have to ask what is an "iron brush"? Do you have a pic or link of what it looks like?
ThanksLast edited by carspainc; Nov 7, 2004, 05:17 PM.
Originally posted by carspainc.com
i do use my customers power...
the machine i should be using needs to leave the carpets pretty dry as i reall cannot afford to come back and fix any spots due to wickering .
what i found out , basically works is keeping the carpets fairly dry and use a buffer to agitate the carpet fibers... then **** the loose stuff and moisture up with my shop vac.
this will be ok on 90% of the spots
then i used a spray on more subborn stains...
but i wish there would be a better solution to my problem
BTW eric i appreciate all of your input and i am sure everyone else here is as well ...THX again
Since you are using clients house power I would look for a machine which meets the following specs:
1. Uses 20 amps or less (as this is the most common breaker/ outlet amperage)
2. Most water lift for the amperage
3. Temperature of heated water (in tank and at nozzle) (water temp can make difference with some stains and materials.)
4. Pump pressure (PSI, adjustable or non-adjustable)
5. Local service center (not really realted to clients power, but something to consider)
6. Spotter carpet machines (just another option)
7. Something made for professional and daily use
Another item to consider purchasing is a steamer to use on heavier or problem stains, before cleaning.
EricLast edited by Teak; Nov 11, 2004, 06:32 PM.Talk it over folks. Communication is the key.
--Jerry Springer
I think this maybe the ultimate extractor, but would hate too pay the electric bill after usiing this one. Definatley for someone with a fixed location shop.
Eclipse machine
EricTalk it over folks. Communication is the key.
--Jerry Springer
