Hi everyone,here's a good little,simple but effective tip when you're cleaning your inside windshield and dash. Some cars are tricky because of the severity of the angle and akward sitting position.
Firstly,It's not my tip,but I liked it so much i've employed it ever scince.(Taken from an episode of Overhaulin' - "love that show!"
This tip is to prevent your dash cleaner (with preserving oils) from getting on your glass and the glass cleaner getting on your dash when you get right into the tight angles where it's tricky.
By using a sheet of clear plastic which is approx. 0.3-0.5mm thick x 1ft long x 1/2ft wide,(length and width:whatever you feel comfy with),wedge it between the dash and the glass.Flip up or down to whatever side you are doing.[This clear plastic is less than 1/2mm in thickness and is produced in large rolls.It is rigid and flexible,and easy to cut.It is very inexpensive and can be found at DIY stores].
I found this tip great as i hate cleaning the inside of the windshield(especially on a hot day).I find it difficult to get them smear free at the best of times without any dash cleaner touching it.The other problem is getting glass cleaner on your plastic surface which can discolor it.
P.S. I havn't seen overhaulin' for a couple of years now.Is it still on the go?
