Carpet Cleaning Brush
  • Carpet Cleaning Brush
    I was a detailer at my local Honda/Chevy/Hyundai dealership about 2 years back and I remember having this air powered rotary brush we used to clean carpets with. I would like to own one for myself but have no idea what exactly it is called or where to get it. I guess if I knew what it was called I could find out where to get it. Anyhow, does anyone know what I am talking about or where to obtain one?
    I don't know about air powered. But I know you can get a carpet brush that fits the Porter Cable (G-100) polisher at Top of the Line.
      Re: Carpet Cleaning Brush
      Hi per4mancemonster,
      As to the carpet cleaner, I've never heard of anything like this before but it sounds interesting. Did it work good?
        I looked at Top of the Line for that brush you mentioned and could not find it. What area is it listed under?
        Obessed with making it shine!
          Re: Re: Carpet Cleaning Brush
          It worked excellent! It was a good addition to the steamer. The place I found it most useful was on the floor mats and any caked in crud in the carpets. I pretty much use the steam machine for anything else. All in all though I found myself using this peice of equipment quite a bit when I was detailing.
          MG
            Details3,
            Go to the area for PC Polisher and pads. Then go down to 4" accessories. It is in that section. It is actually designed for a Cyclo. But it fits the PC. The only difference is the Cyclo uses two of them.
            I have not used this brush, but it looks promising. Hope this helps.
            Don
              Yes, the brush/scrubber attachment for Cyclo & G100 work great for agitating stubborn stains...and for speedy clean up of floor mats. I used it for years in my detail business.
              I later switched to an air tool (something about using an electric hand tool around wet carpets just made me nervious I guess.)
              Check out your local Dynabrade distributor for a great palm size air tool with a brush attatchment.
              Jason "Waxman" Rose
