what to use?
  • what to use?
    ok... so i haven't tried to fix this yet because I wanted to get some opinions first. This is a 1999 Mercury Cougar and I'm wondering what product would be best to try and the methods.
    Re: what to use?
    I would try APC cut 4:1
    AeroCleanse, LLC
    www.aerocleanse.com
      Re: what to use?
      APC or APC+? I dont have any of it so i'll have to order some.
        Re: what to use?
        Both would be ok, though if you know what the stain is APC+ is more of a degreaser. So if it is grease, that might be the one to get.
        And since it is a headliner, you cant soak it the same as you would a floor mat. You have to kind of spray a towel, then blot a bit, spray some more, blot some more, etc... Let it dry, check your work, try some more, etc. You dont want to soak it.
          Re: what to use?
          not sure what it is (bought the car used and it was there when we bought it). Would it hurt to use APC+ even if it isn't grease?
            Re: what to use?
            No, wouldnt hurt at all.
            The other main difference is that APC will foam, while APC+ is non-foaming.
              Re: what to use?
              thank ya much.
                Re: what to use?
                Here's the large size photo...
                Be careful you don't press too hard on the headliner while trying to work a cleaner into the stains as you can stretch the material and cause it to sag.
                These types of stains can be hard to remove because headlines are just plain hard to work on.
                Another product you might try that you might be able to find retail is our
                Quik Outâ„¢ Carpet Stain Remover
                It's also available in an aerosol
                Quik Outâ„¢ Carpet & Upholstery Cleaner
                If you call Customer Care they may be able to help you locate a store near you that carries these products.
                1-800-347-5700
                  Re: what to use?
                  if it were you mike, would you try quick out or APC?
