Recommend an ink remover?
  • Recommend an ink remover?
    I was noticing in my wife's car, there are a couple of small pen marks under the door handle leather.
    Can anyone recommend a process and/or product to get the marks off? I don't want to start mucking around, chancing that the leather will fade a bit or spread the ink.
    Thanks all !
    Re: Recommend an ink remover?
    Hi .
    Have you try with white alcohol 90 %?
      It works on clothing so I would try HAIR SPRAY...the liquid kind not the aerosol kind...takes it right out of clothes so it might work...
      Bill Poirier
      West Seneca, NY 14224
        I have successfully remove ink using Isopropyl alcohol and a cotton cloth. I have also used a Magic Eraser with good results. With either I must caution that this is dangerous. The leather and vinyl in most of our cars is coated with a urethane base color top coat. If you remove too much of this you expose the underlying material and it is pretty ugly. Be very gentle with whatever approach you use.
        Jim
        My Gallery
