I applied two good coats of the Perfect Clarity coating not too long ago. Today, I baked the headlights open to install projectors. I noticed my fingerprints are now imprinted on the lens, I'm guessing due to the coating. What's the most gentle way to remove it so I can reapply after I get everything back together?
Removing Perfect Clarity Coating
Re: Removing Perfect Clarity Coating
You could try polishing to see if it does anything.
Do you think the fingerprints were caused by the baking in conjunction with the heat or is it like the coating never fully hardened? Not to hijack the thread but I'm doing some testing now with the Keep Clear coating on a motorcycle windshield and if it never gets fully hardened that's going to change things completely. I think, based on previous posts, the Keep Clear is the one you used, correct? The blue and black bottle?Lydia's Mobile Detailing
2007 Honda ST1300 - Silver
Keep Clear, yes, the new black and blue aerosol bottle. I knew the name but apparently had a brain fart when I typed it out, lol. The coating does dry/"harden," and I believe it was indeed caused by the baking. However, it was only set to 180*F. I'm curious if strong summer sun in California or Florida, for example, could cause the same thing to happen though?
Originally posted by roushstage2 View PostKeep Clear, yes, the new black and blue aerosol bottle. I knew the name but apparently had a brain fart when I typed it out, lol. The coating does dry/"harden," and I believe it was indeed caused by the baking. However, it was only set to 180*F. I'm curious if strong summer sun in California or Florida, for example, could cause the same thing to happen though?
I have absolutely no idea how hot housings get in the sun. One of those things I could use an infrared thermometer on if I ever buy one, lol. It doesn't seem unreasonable to think they could get up to 160*F-180*F in the direct sun when the ambient temp is say 110*F. Again, I don't know though.
Anyways, it took A LOT of elbow grease with some Plast-X, but I got all of the old coating off. Once I finish up with everything else and I know it's good to go, I'll put some more Keep Clear on! For now, I think a coat of UFF will work.
Thanks all!
That's good news that plastx was able to get it off.
