Dust Inside Headlight?
  • Dust Inside Headlight?
    The outside of the headlight is pristine but it looks like some dust or dirt built up on the inside. I bought the car this way so I have no idea what caused it. Any ideas what
    Re: Dust Inside Headlight?
    What make of car?
    Most headlights these days are a sealed unit, so nothing should be getting inside, unless maybe something happened when a globe was being replaced.
    Have you ever replaced a globe? If not, I'd take it back to the dealer..
      That's a known problem on Toyotas.
      My issue is that condensation has formed in the right, passenger-side xenon HID headlight of my 2004 XLE Limited Sienna...the light bulb has also blown...evaluation by my independent mechanic reveals that the entire assembly needs to be replaced at a cost of $900... My searches of SiennaClub...
        Sounds like there is a leak somewhere around the headlight.
        99 Grand Prix
        02 Camaro SS
          Did you ever figure this out?
          99 Grand Prix
          02 Camaro SS
            If there is a dust and dirt in there in it differently a leak somewhere around the headlight, if your headlight has never been on from the where to change the light bulb is.
            you can do two things, first, take of an headlight heat up the seal that right in the middle between the light back housing and the lens and reseal with new seal or second, buy a new headlight T_T......
              When i brought my gti in the summer, one of the lights was dull inside.
              On checking, the bulb access cover had snapped and was letting dirt in.
              I had a spare cover from the first gti.
              I already had the bumper off for an intercooler replacement, so only took a min to take my light off.
              I took the bulbs wiring and level motor out, then i filled it with uww shook it, let it soak and then rinsed it.
              Dried it out.
              Looks like new but on close inspection theres a few water spots inside not on the glass just on the mirrored reflector, but it's a trade off.
              Soppose i could have used distilled water for final rinse.
