Originally posted by Murr1525
View Post
PlastX leaving extremely small Swirls on Headlights?
Re: PlastX leaving extremely small Swirls on Headlights?
Try using M205, as it is less aggressive than Plast X and should probably take them out
How were you applying the PlastX?
I answered your other thread and just seen this one.
I think the problem is just so many different types of plastics out there.
PlastX on another type of headlamp might be fine.
So today I decided wetsand my headlights with 2500 grit sandpaper to clear it up a little. After wetsanding the headlights using the correct procedures, I used M105, LC Yellow Pad 5.5" and a PCXP at 6 speed to remove the sanding marks.
M105 and the PCXP did a quick and fabulous job at removing all the sanding marks in one pass. I did two more passes to ensure I got even coverage and at this point, the headlights are extremely clear.
As a procedure, I decdied to use PlastX to top it off. I decided on this because ADS sells a Heavy Duty Headlight Restoration Kit that teaches the use of PlastX after M105.
After working PlastX into the headlights for around 3mins non-stop in circular motion and with some passion, i realized that I added more swirls in the headlights than before... I immediately gave the headlights a pass using M105 and the swirls created by PlastX is gone.
Not believing what I see, I gave PlastX another go on the same headlight, more swirls. Some of you may say that I am not working in the product long enough. But trust me, I was literally diminishing everything there was on the pad.
Here is a picture of the swirls created by PlastX:
Excuse the white Infiniti M45 in the backgroundTags: None
