ADS: HD Resto kit question
  • ADS: HD Resto kit question
    Kit includes:
    M10512 Ultra Cut Compound 12 oz.
    G12310 PlastX Polish 10 oz.
    325 Velcro Backing Plate for Drill
    301G Wool Cutting Pad (1-Pad)
    330G Foam Polishing Pad (1-Pad)
    S2000 Sand Paper (4 Sheets)
    E-7200 Backing Pad for Sand Paper
    85-653 Wool/Foam Cleaning Brush
    Kit includes step-by-step instructions
    Presuming I keep the pads clean after using, should I be able to use the kit several times?
    The S2000 Sand paper - is that just 4 sheets of 2000 grit? Wouldn't it be wise for me to get some 1k, 1500, and possible 2500 or 3000 grit?
    Re: ADS: HD Resto kit question
    I think it is supposed to be a one time thing.
    But I am sure you can use it multiple times
    Someone else will chime in.
      Well you can use the hardware for a long time
      your M105 should last you a few (3) cars but don't use less then recommended on the first car.
      I think you might need to get more product if you want to do more than 2 car
      Also put one sheet of that sand paper in water with a dash of soap
      Store the rest 'till 2020.
      You shouldn't need a heaver git unless you have some deep orange peal or ruff paint
      I have 1000, 2000 & 3000
      I barely use 1000 and I'm starting to question even using 3000
      M105 should remove 2000 sanding marks with no problem
        Thanks for the replys guys. Any more suggestions or inputs are appreciated. I'm planning on using this kit for my car and my wife's car...then doing a co-workers car for a small fee. I have restored the headlights on my MIL's van with that $20 kit from the parts store that comes in the silver packaging with really decent results.
        EDIT; Results of that $20 kit found here. http://www.meguiarsonline.com/forums...017#post305017
          I guess my question should have been worded differently. I was asking more about the pads...As long as i keep them clean, I should be able to reuse them a few times correct?
            yes, a year or so depending on your useage.
            I have pads from....I can't remember when I got them
            Just take care of them and they'll last
              thanks for the help
